hello all, has anybody every tried to sound proof their car ?
If you take the door trim panels off you will see the door has the outer panel you can touch from outside the car and an inner panel that the door mech is attached to & the trim panel. Both need sound deadening added to them to improve insulation & sound deadening once you have the panel off you will see what I mean.Hello I would like some more info about the outer skin you mention in order to fix the shut sound.
Generally hatchbacks will benefit greatly from this.my boot seems really noisy, would lining all under the spare wheel and stuff help with that?
