I'm creating this for Subz but thought I'd share for all.
Remove the cowling from the steering column. Should find two screws in the bottom part, then the top just lifts off. You might find it easier if you release the column tilt lock.
Two small screws hold the stalk on.
Two connectors are attached to the stalk. Press the tabs in and prise the connector out at the same time to remove them.
Connector as above.
Under the bonnet in the engine bay you'll need a 15A fuse as shown. This fuse box is located left of the battery.
Then add the relay, located left of the coolant expansion tank on the left side of the engine bay.
![IMG_0590.jpg](http://i294.photobucket.com/albums/mm117/edkeating/Car/Almera/How%20To/IMG_0590.jpg)
![IMG_0592.jpg](http://i294.photobucket.com/albums/mm117/edkeating/Car/Almera/How%20To/IMG_0592.jpg)
![IMG_0593.jpg](http://i294.photobucket.com/albums/mm117/edkeating/Car/Almera/How%20To/IMG_0593.jpg)
Connector as above.
![IMG_0594.jpg](http://i294.photobucket.com/albums/mm117/edkeating/Car/Almera/How%20To/IMG_0594.jpg)
![IMG_0595.jpg](http://i294.photobucket.com/albums/mm117/edkeating/Car/Almera/How%20To/IMG_0595.jpg)
![IMG_0596.jpg](http://i294.photobucket.com/albums/mm117/edkeating/Car/Almera/How%20To/IMG_0596.jpg)
