Mov's Micra
Will be good to see you there and what she can do.
Low 13's, high 12's lol.
How different does it feel compared to the sr20de micra?
Hopefully not too much lag, i'am assuming with low boost it will just feel like a smooth but larger vvl kick from when boost comes in assuming 4-5krpm all the way to redline 7500rpm ish?
Just picturing my old fwd sr20det sunny which flew once rolling, this must go very well...lol
You have no lsd right, i can hear the wheel screach on gear change and when boost comes in.
I aiming to beat my P.B that's it lol ;)
seriously i think mid 13's?! traction is not a major issue though atm when boost kicks in its a different game haha
Peak power is till about 6800ish iirc
What 14.51?
I hope so too lol
Or you just turbo'd it for the dump valve sound...lol
You bro, white bus, has been quite lately on here, he cool?
What 14.51?
I hope so too lol
I turbo'd it for the the feeling i get on boooost!!! , like i said before times/drag racing i only do it as a bit of fun
Yeah my bro still got his but been busy at work, should be a update soon
Do you get much torque steer with this and are you getting any traction issues in lower gears also?
Sent from my  iPad® using Tapatalk HD
no torque steer at all... but its been fully polybushed and arb/coilovers helps a lot too
Traction is a bitch but again R888's help
Had another epic day with the micra today!
Started it off at 5pm finished at 9pm
Tunnel runs
Country side roads
Was EPIC!!!!
Iv had it for less than 3 day tax and tested and have done about 1000 miles of constant booosting and abusing haha
omairsaleem
Speedo is acting funny sometimes, the speedo/rev/temp/fuel counter goes up and down... which cause the engine speed to drop when the speedo has a mind of its own, only happens for split sec or two as soon i let of throttle its back to normal? it cant be the map cause it only happens on very few occasions and only when the speedo goes crazy does the engine hesitate!
Can it be the maf, speedo or speed sensor? or any other ideas
Dude, please do me a favour (or a few to be exact)!
1. Put the stock rear plastic (black) bumper back on
2. Fit a much smaller exhaust tailpipe (something stock looking)
3. Buy a set of wheel trims and cable-tie them to the wheels to make it look stock!
THEN YOU WILL HAVE THEE BEST SLEEPER IN THE U.K. :)
