Best Almera, PERIOD
Yeah dude, all solid, no rust at all - shell and bodywork wise there are 3 bug bares
1) Bonnet has lacquer peal
2) Passenger side rear quarter as a trip of paint come off (where he's removed his sideskirt)
3) Passenger side rear arch has a small dink and paint come off
(You can see all of them in the photo's unfortunately)
4) Wiper arms have paint flaked off
Engine wise
1) Timing is very very slightly out which means 5/6k to the limiter doesn't pull that hard (easy fix)
Interior wise
1) been sitting around for ages and has a little bit of mould appearing which I will be blasting out and giving a deep cleaning up session at the weekend
2) Tape player doesn't work ='(
3) slight air leak from drivers door seal
Suspension wise
1) Rear subframe bushes have play making it a bit boaty
Good points
1) Fresh engine rebuild
2) Freshly under sealed
3) HKS Cat-Back Exhaust system
4) Body work in pretty good condition
5) 1 years MOT
6) 6 months Tax
7) IS REAR WHEEL DRIVE AND A TURBO =D
You'd have got something to do with ripping and arsehole.
Being torn one for not sorting the "timing" sooner
....Phone....
Let me guess front wheel drive bread van with as aspect of making it that bit closer to the s14 you should have bought? Your plan is to fit a t28 turbo the to the sr20 and fit some s14 leathers? Afterwards hand brake hero to prove its worth in the local Asda car park? ;)
Sent from mobile device
Jokes on you, he doesn't have an N15 ;)
If i get another turbo car I'm putting a duck caller on the dump valve it's the best mod for a turbo ever.
Sent from my GT-I9300 using Tapatalk 4
this would be hilarious to see/hear lol
I remember a party whistle roll out thing being attached to a dump valve
Sent from my GT-I9505 using Tapatalk 4
