N16 4x114.3 multi fitment Trouble
Hi guys I bought 4x114.3 5x114.3 multi fit alloys
And I know the almera is 4x114.3 so I bought them but the wheel won’t go on. Have anyone else had this problem?? Et is 47 on the alloys but the team on the steelies are Et47 which dosnt stop the wheel going on. I’ve tried juggling the wheel around but still don’t understand why
The centre bore on the wheels is probably too small for your car. I'd measure that and compare to your old wheels
Cheers for the reply the center bore is 68.1 and the almera 66.1 so I know that’s not a problem but think I’ve sussed it and there not gunna fit, the vertical length is good at 114.3 but the the horizontal stud to stud is 2cm smaller which I still can’t work out but hay ho money down the drain
That's impossible if they are 4x114.3, as that is literally the measurement.
Maybe you were mis-sold/listed wrong?
Crap either way.
Check centre bore nissan is 66.1
