2JR short shifter kit works with N16 DCi?
hello Ed
Can you tell me if this material from 2J RANCING works and which plugs can I have come here mentioned which is red ??
Sentra/Maxima 2JR Nismo Short Throw Shifter / optional Shifter Bushings
Delrin Bushing Combo Option
  • Add Complete Bushing Set (3 PAIRS, Full SET???
If you have a 2004 Sentra, please measure your top cable ring outer diameter if you are order shifter bushings ONLY?
  • 1.1" Outer Diameter - same size as the lower ring (2002-2003)????
  • 1.4" Outer Diameter, larger than the lower ring???
