I have an Almera GTi 1998 UK model. When I set/unset the alarm (NATS, factory fitted) there are problems with the indicators - sometimes both left and right flash at the same time when indicating left or right - sometimes when driving the alarm sounds, only a single beep, but around every 15 to 20 seconds (most annoying). Sometimes the alarm seems to be off when it’s on – and vice versa. Also, when driving and not using indicators there is still an intermittent tick, tick sound which seems to be coming from under the dashboard. As the car is used very little I often disconnect the battery for long periods. Has anyone experienced this problem – how can I disconnect the alarm system? Anyone have any ideas?
