1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
Anything to look for?
Discussion in 'Newbie Section' started by Markyh123, May 8, 2018.
  1. Markyh123
    Markyh123
    1
    0
    Model:
    Sve
    Chassis:
    N16
    Hi, been looking 4 a runabout 4 work and have come across a 2005 1.5 sve, is there anything I should be checking for when viewing?
    It's around 80k miles, 10 month mot for under 800
    Cheets
    Mark
  2. Nugget Beercase
    Nugget Beercase
    193
    36
    Finland
    Model:
    Saloon 1.6 GXe
    Chassis:
    N15
    Among basic "buying a used car checks":
    - Inspect the radiator support beam behind the front bumper for rust. Very common on the N16 models to rot.
    - Make sure the rear brakes and handbrake work properly. (Rear wheels/rims not hot to the touch after a drive, handbrake keeps the car stationary on an incline)
    - The QG engines like the 1.5 is are notorious for timing chain wear resulting in various issues. (Hard to start, stuttering while driving/accelerating etc.)
    If there is a check engine light, you need to know what it is for. If the code is cam or crank position sensor related, chances are the chain is no good. There is no easy external way to tell if the chain is bad.
    If the service history is ok (oil has been changed on a regular basis and frequently enough) and there is no check engine light present, and the engine sounds and feels smooth, the chain is probably ok (for now).
    Other than that the N16 is a pretty solid car IMO. Some smaller faults can arise (CD player/display unit related etc.) but I didn't list faults that do not affect the reliability/driveability side.
    V-SpecII, Tony_CRO and Markyh123 like this.
  3. V-SpecII
    V-SpecII
    1,493
    210
    Mani
    Model:
    2.2 DCi SXE
    Chassis:
    2005
    Wow Nugs quite a write up much respect. x
  4. edk
    edk Addicted to Torque Staff Member
    25,648
    6,335
    Hampshire
    Model:
    SXE DCi
    Chassis:
    N16
