yep checked is all if it was not in the head unit does not work its the earth when i held the aerial whilst in there i picked up a local station but once its screwed in dont get it
Sounds like your arial is goosed. You tried putting your standard headunit back? You could have damaged the arial changing it over.
Hopelessness is right, the cage and plastic may not be a sufficient earth on the N16 and ideally a seperate earth should be found. Using the instrument cluster is not a good idea. I can't remember where I ran it to.
