As some of you know, im starting a build on a DE.. yes DE!!
Was going to do somat small and simple but plans regularly changed :no:
So, before ya'll say it, and for whatever reason you do, its going to be a DE!
My wish*ehem* sorry, spec list is as follows:
Gonna be using a RR head thats already had headwork done by Norris Design
Catcams 518s
BC Valves Springs & Retainers
New Shims/Guides
Supertech Valve Guides
New Valve Stem Seals
.8mm head skim
1.2mm head gasket
90mm 12.5:1 pistons
Darton sleeves
All ARP Bolts
Golden Eagle Head Studs
All ACL Bearings
Apex Rods
91mm Stroker Crank
Lightened pulleys
Fully balanced bottom end
VE Oil Pump
Custom or 3" Header
Custom intake or ITBs
Fidanza Fly
ACT Clutch
255 Fuel Pump
Theres prolly more i've already missed out..
Catcams 518s
New Shims/Guides
.8mm head skim
1.2mm head gasket
90mm 12.5:1 pistons
Darton sleeves
All ARP Bolts
All ACL Bearings
Apex Rods
91mm Stroker Crank
Lightened pulleys
VE Oil Pump
Custom or 3" Header
Fidanza Fly
ACT Clutch
255 Fuel Pump
