Im after a bonnet vent to keep my engine that bit cooler coz it gets hot under there after i fitter my header,and i was just wondering if any of you guys had any ideas?
what you goto think about is the areo dynamics of the thing an evo vent is designed to drag air in through the front grill & out via the bonnet vents.
my bonnet vent helps keep the inlet chamber cool along the lines of a CAI.
so depends what you wanna do mate then shop around for a vent
If things are getting hot under the bonnet, get some header wrap. Made by ThermoTec it's called CoolIT and is bloody marvelous. Keeps the temps down in the engine bay and I can actually touch the header (with the wrap on obviously) even after a long run in the car. Without this I'm sure my fingertips would have welded themselves well and truely !! Also keeps the heat in the header which helps with performance as hotter gases travel faster.
