CDplayer problems
Iam trying to establish weather or not if i remove my CDplayer from myN16 2005 almera ,will i need to put in a code when re instaling it or not, or is there another compatable CDunit that i can use to replace the original one ?
as it's coded to the ecu, it you should be able to remove and refit it, without requiring code again, but you can't just replace it with any other unit.
thanks for the info ragt20 but how can i be certain that it is , how can i find out if i take it out and it requires a code on refit and i dont have one will my heater still work ?
