Chassis Alignment Setup Records
edk
Addicted to Torque
Staff member
As title. GO!
Good way to compare set-ups and chassis.
  • Like
Reactions: IT
edk
Addicted to Torque
Staff member
With BC Racing coilovers and bottom mount camber slots set to -1° camber.
It was decided to set front toe to 0 so that under acceleration you would get a slight toe in when needed.
Previously I had a slight toe in set but this feels better. Steering seems quicker to respond and get better on power grip in the corner.
What I found interesting was the -1° camber on the rear beam. It's noticeable though just looking at it.
Notes:
Stock bushes front and rear.
rowdy-GTi
Moderator
Staff member
From what i rememeber the rear spec looks pretty similar to mine pre-bending. The n15 has neg` rear camber.
i upload mine hoping its usefull for some1
first column is previous values the second the final ones
first row is toe
third is camber
fifth caster
i dont know how to translate the rest
