Driver's door lock
Discussion in 'Newbie Section' started by Des Lavender, Nov 15, 2018.
  1. Des Lavender
    Des Lavender
    1
    0
    Model:
    SE Auto
    Chassis:
    N16
    My driver’s door inside handle stopped working when I got home yesterday. I can drop the window and open the door from the outside. Any ideas for the cause and a fix please?
  2. Liam
    Liam
    13,045
    4,628
    North Devon
    Model:
    Burner
    Chassis:
    Oil
    Yes had this issue on mine. You need to remove the door card as the rod may have unclipped itself from the back of the handle. Should just be a case of clipping it back on.
    Dismiss Notice
