I thought this may be a good idea to compare power outputs etc. All models /makes etc.
If its in the wrong section admin can move it or creat a new section.
Please list modifications and post a dyno sheet. Dynojet and dyno dynamics figures prefered as they generally give more consistant results.
191.79whp
UKDM RR DE.
`CatCams` 518 with 298/288 duration 11.6mm lift
16VE Pistons
Eagle rods
ACL Race bearings
Mildly ported head with Ti retainers / springs
HKS induction kit with race element
64mm throttle body with coolant bi-pass
Interanlly polished inlet manifold
Thermo spacers
Fujitsubo VE header modified to fit DE
2.25" Catback
Decat
Meziere eklectric water pump
PAS delete
Underdrive crank pully / alloy ALT pully.
NISMO AFPR
OE 259cc injectors
NISTUNE ECU with 8200rpm rev cut
VZR N1 close ratio LSD gearbox
11lb `Competition Clutch` steel flywheel
4 Puck `Competition Clutch` racing clutch
191.79whp
UKDM RR DE.
16VE Pistons
Eagle rods
ACL Race bearings
Thermo spacers
2.25" Catback
Decat
PAS delete
NISMO AFPR
OE 259cc injectors
