Faulty Passenger Door Window N16 1.5 S
Discussion in 'Newbie Section' started by stuffedhaggis, Jan 27, 2017.
  1. stuffedhaggis
    stuffedhaggis
    14
    3
    Model:
    1.5 S
    Chassis:
    N16
    Hi all,
    I purchased a good condition N16 55 plate 1.5 s a month or so back. Since having the car the Passenger Door Window will not go down with the switch on that side. It will do down with the switch on the driver side though.
    Any ideas on how to pinpoint the problem ? I am happy to replace parts if needed.
  2. Nugget Beercase
    Nugget Beercase
    215
    39
    Finland
    Model:
    Saloon 1.6 GXe
    Chassis:
    N15
    Since the motor works, chances are that the switch itself could be at fault, or the wiring for the switch. I'd start by disassembling the door card and checking the wiring and switch for obvious visual faults (disconnection of wires, or broken wires) and then checking if you get power at the switch.
  3. mike 257321
    mike 257321
    5
    0
    folkestone
    Model:
    tino 1.8
    Chassis:
    n16
    My drivers door window works, but the 3 passenger windows don't. So can't be the relay or fuse can it?
    They do not work from any of the door switches.
    I've taken the fuse box cover off and the diagram on the back lists everything except the window fuse!
    Heeeellppp.
    Mike
  4. mike 257321
    mike 257321
    5
    0
    folkestone
    Model:
    tino 1.8
    Chassis:
    n16
    Bought a new driver door switch unit from ebay - all sorted.
    Dismiss Notice
