hi is removing the front bumper on almera gti n15 a hard job or easy as need to take off and respray it. thx guys
like itTheSam101 said:Try Bensketts method, Reverse down a high kurb lols
Gynx said:First take off:
Indicators
Grill
Possibly Arch Liners
Diconnect Fogs
once thats done
3 Bolts under where the Grill goes
Possibly 1 or 2 Bolts in the corners where the indicators were (Only found 1 in each corner on mine , but there is bolt holes for others)
2 Bolts underneath the bumper , should see little arms attaching to the underside
In each wheel arch , you gotta remove the liner so youve got access to the top corner of the bumper. Theres 1 bolt holding on each side.
Remember to grease em up before replacing , or replace if rusty
