Headlight Problems?
Discussion in 'Newbie Section' started by EvskiPal, Jan 9, 2013.
  1. EvskiPal
    EvskiPal
    2
    0
    Model:
    S
    Chassis:
    N16
    Hello, I have just joined this forum to see if anyone can help us with a problem we seem to have with terribly, dangerously dim headlights. They are fine on full beam, but obviously one can't drive around like that, and that's where the problems start. It is like driving with candlelights, we are totally blinded, when other cars overtake us, we get an idea of how bright our lights should really be. We bought a used 2006 Nissan Almera 5dr hatchback in September (DK56 reg). Mileage apr 52,000 at the time. Soon after, we noticed this problem. Recently went to garage where we purchased the car and the garage owner changed bulbs to see if it would improve. Not much improvement, still driving in dark. I read online that there has been a recall on Almera headlights a while back but this has lapsed. So went back to garage owner and he agreed to replace just one headlight, as he seems to think just one is at fault (which we don't understand). Can anyone help or give any advice as to what would be best to do? Have you had similar problem or know anything about this headlight issue? Would Nissan still assist even though we are the 3rd or 4th owner and the car is over 6 years old? thank you!...
  2. bnicholls92
    bnicholls92
    703
    62
    Model:
    Flare
    Chassis:
    N16
    You need to check with nissan if the headlights were replaced in recall. I'm not sure if this car would come under the recall but is worth a check
  3. EvskiPal
    EvskiPal
    2
    0
    Model:
    S
    Chassis:
    N16
    Thank you - how do you do this? just ring up and give them the car reg and they will tell you?
  4. bnicholls92
    bnicholls92
    703
    62
    Model:
    Flare
    Chassis:
    N16
    I'm not sure you may be able to check online or phone nissan with your VIN, it will be stamped on the firewall in the engine bay starting in SJN
  5. edk
    edk Addicted to Torque Staff Member
    25,649
    6,340
    Hampshire
    Model:
    SXE DCi
    Chassis:
    N16
    Yes give your local dealer and call and they will check your plates and or VIN to see if any recall work is outstanding.
    Note though that cars after 2004 should have been fitted with the updated versions of lights and anything else that fell under a recall.
  6. happyharrysco1
    happyharrysco1
    6,134
    93
    Aberdeen
    Model:
    SR16VE
    Chassis:
    N16
    if there is a date stamped on the white sticker on each headlight they are the newer design, if they are the newer design try using nightbreaker+ bulbs to improve your light output
    .....phone.....
  7. Liam
    Liam
    13,044
    4,630
    North Devon
    Model:
    Burner
    Chassis:
    Oil
    Im with happyharry, osram nightbreaker+ bulbs make a massive difference and are well worth the £12.
  8. JT101
    JT101
    3
    0
    Model:
    Nissan Almera 2005
    Chassis:
    N16
    Just want to say how pleased I am with the DEPO lights I got from Ebay. It is literally a difference of night & day (Excuse the pun). To be fair it is partly the xenon bulbs I put in there, but without the DEPO lights those bulbs don't make a bit of difference. I can actually see where I'm going now!
  9. Keithvfr
    Keithvfr
    2
    0
    Model:
    Almera
    Chassis:
    N16
    Hi , ive just bough a 2004 Almera
    And yes the headlights are crap
    Has anyone tried swapping them around
    Ie: having the outside one as low beam ?
  10. dwaterh
    dwaterh
    1
    0
    Model:
    S
    Chassis:
    2006
    Hi, I have been putting up with the crap Nissan headlights since I bought my late 2006 Almera S in January this year. Output is woeful, never driven a car with such poor headlights. Getting sick of using the headlights from the car behind me to see where I am going! I even put nightbreakers in and it made about 10% difference, but still could not really see where I was going.
    As Autumn Winter will be here soon, I have just replaced the Nissan ones with TNY ones from ebay (£90ish for pair) fairly easy to fit, and took the chance to replace my bulbs as well to nightbreaker laser (not xenons) , and new side bulbs etc. The difference is AMAZING, just how I expected it to be when I bought the car.
    Every Almera needs this upgrade. Well worth the money, if like me you had been putting it off for a while. Lights seem to be aligned ok, and lifter motor seems to work fine which were taken from the original Nissan units - although they were not very easy to remove. took me while to work out how to get them out without destroying them.
    As I had the units out, I also took the time to refix the front bumper - as there is a little clip which does a crap job of holding the side of the front bumper on, now held with cable ties and will no longer pop out every five minutes.
    A considerable upgrade - do it if you are pondering getting replacement lights from ebay, wish id have done it sooner now.
  11. Peter John
    Peter John
    2
    0
    Essex
    Model:
    SVE
    Chassis:
    SVE
    Sorry to bump an older post but my Almera 05 headlights are rubbish, where do you get the Depo replacement ones from, is there any other alternatives that are as good?
    TIA,
    Pete.
    Dismiss Notice
