Help finding air bleed points and drain plug locations please
D
D Cox
Hello again, I still need to find the AIR bleed points and the drain plug to put antifreeze in my Almera. Anyone able to help with advice or a diagram?
I don't know myself, If know one else replies with the answer my best bet is to go to your local Library and find the Haynes manual for the Almera. It should definitely have some info in there. Or you could go Halfrauds and buy one if you want to waste some money...
well i did mine a month ago and if yours is a GA engine then theres one just to the left of the fuel rail near some sensor and one on the right hand side of the block a third of they way down from the top id say.
D
D Cox
Thank you - Engine block drain point also if possible
Thanks for the help. Does anyone know where the engine block drain point is please? Unfortunately Haynes do not do an Almera handbook, I don't know why!
That`s got me confused now, but no idea for either model!
D. Cox, please take a look @ the pic below of my cars (same as my avy), & tell us which one you have.
The grey one is an N16, the blue one is an N15.
Hope this helps.
D
D Cox
Sorry, yes it is an N16. Thanks for your interest, D Cox
