S SliverN16 May 10, 2008 #1 hello can anyone point me in the right direction to find my datascan diagnostic port on my N16 thanks
F Fred May 10, 2008 #2 If this is the white plug that looks sorta like a SCART socket, it was behind the ashtray, under the push-out cupholders on my Phase 2, iirc!
Darren198712 Just chillin' May 10, 2008 #3 Almera Guy said: If this is the white plug that looks sorta like a SCART socket, it was behind the ashtray, under the push-out cupholders on my Phase 2, iirc! Click to expand... its not ??? I am sure. I plugged my mates snap on unit in the other day its near where the clutch is.
Schnakey May 11, 2008 #6 Under the steering surround, in the middle, right on the bottom of the driver's side of the dash.
S SliverN16 May 11, 2008 #7 I found it thaks for your help guys nissan seem to have changed the connector shape my old nissan consult does not fit nevermind
wraith May 11, 2008 #8 I'd guess the N15 Almeras use OBD-I (grey connector I think) while the N16s use OBD-II (white connector I think)?
Schnakey May 11, 2008 #9 Yep, N16 is OBD2, the cheapy scan things work on 'em, think they're about £20 off the bay
H houston May 14, 2008 #10 or just flash the code yourself, all you needs a paper clip! im tryin to find the link but havin trouble, its pin 9 and 16 iirc. but im still looking
H houston May 14, 2008 #11 i was right, short pin 9 and 16 http://www.primera-egt.com/FSM/P11-144/codes.pdf
B Blazt Aug 21, 2008 #12 Blazt also do a cable and full datascan software for the N16 now as well. www.blazt.biz/products/obdii.php
