I did quite a lot to my 52 plate N16, 4 branch, full system, 200 cell sports cat, lightened flwheel, custom air shrouded air filter setup. P2 box
First mod for an N16 if I had another one would be the apex springs, and a whiteline front strut brace, these transform the car, along with a set of 17s on low profiles you'll be taking corners faster than anyone will ever expect.
next thing to do would be the k&n induction kit, then grab youself a cheap stainless sanitary bin from sainburys, remove top and bottom and it slips right over the k&n, insulate the battery terminals so it won't arc out, then remove the passenger side fig/fog cover and route your cold air feed through there, that works incredibly well, looks pretty and sounds awesome.
After that I would go with the lightened flywheel/4 branch. You can safely have 1.7 kilos removed off the stock flywheel and make sure you get a new clutch when installing (standard will handle this fine) Ten get a stainless sytem made up with a decent 200 cell cat (long one or your management light will keep coming on and the performance is affected greatly by this)
The P2 gearbox has shorter ratios so is better if you intend serious b-road abuse, and it won't go pop like a p1 box
With all that done my 1.5 SE was keeping up with a clio 16v through the twisties and not really losing much on the straights.
