My Trop Green GTi
after writing my other trop green gti off i bought another from TANGO
finally got tround to doing some of the minor repairs and adding parts that i had bought for the other one
from this
after some hammer n dollie work and a little spray filler (just needs painting)
fitted 4-2-1 manifold and down pipe
getting a catback and de-cat fitted tomorrow courtesy of 2.0lt GTI
fitted my other wheels
then over the next couple of days i am going to fit the bc coilies
replace the boot lid as it has a dent in it above the light cluster
replace the rear bumper
replace the rear lights as one has a hole in the lense
replace the wing mirrors for vzr folding ones (anyone know if there a straight swap)
replace inlet manifold and rocker with chrome plated ones
wing mirrors will bolt straight on youl have to wire up the switches though, there is a guide on here somewhere. :)
The GTi looks really nice in that colour :)
some nice mods allready there, and nice to see you're sorting out the bodywork.
Wow you've already repaired it and all, lookin' good, looks like u changed the alloys too.
Manifold and downpipes look sweet.
I really miss this car!
well i got round to painting it today
is it worth wet sanding before i apply the clear or just applt the clear
wet sand before spraying the clear I say,
either lower the front to match or raise the rear ;)
thanks and im going to raise the rear a little just fitted them and didnt have time to adjust anything
did i read correctly somewhere your at rising sun at the weekend? will check it out there!
yes im going with JNE
Not surprised its rubbing Steve, its on its arse!
Good work mush.
its rubbing at the bottom of the damper a couple others have the same problem going to hit the offending part with a big hammer to move it out the way lol
thanks
not bad considering i havent done it before just need to see what it looks like when sanded and cleared
new tailgate fitted and moved the wiper to the bottom ,replaced the rear lights and raised the back of the car a little
