someone told me that the N14 front absorbers fit to an N15 and they can low the front part of the car with the factory springs...
is it true?
is it true?
They are the same as a p1 n15. Fitting them with p2 springs will lower the front.
U have a Phase one
Fitting different shocks with the same springs will not lower the car, but changing the existing springs to lowering springs will lower the car
are you sure the spring platform is lower for an N14?
Yes N14 front are the same as P1 N15 front.....or at least VERY similar.
Ok , from some pictures I found it really looks like they are the same. I will try to find some used ones and compare them and mainly the spring perch .If everything is good I will try the N14 ones. I need to combine them with my Eibach springs , so that is why the spring perch has to be the same. Right now I have eibach pro-kits for N15 1.4 (front springs are softer , but i don't know how much compared to the 2.0 GTi ones from Eibach). I asked Koni about the rear shocks if they make them any shorter than the stock ones , but no reply yet.
