Need help, gearbox compatibility
Discussion in 'Other Almera Discussion' started by David Gall, Aug 29, 2018.
  1. David Gall
    David Gall
    2
    0
    Model:
    Almera 2004 1.4 SE
    Chassis:
    N16
    Hey all, i was wonderinf if someone could help me out here.
    The gearbox in my 2004 1.4 Almera SE has packed in and i may have a replacement but i do not know if it is compatible with my car.
    The replacement i have been told is from a 1.5 2004 almera.
    Does anyone know, i tried looking in google but im not sure where to look, thats when i found this forum.
    Any help would be appreciated greatly!
  2. Nugget Beercase
    Nugget Beercase
    216
    39
    Finland
    Model:
    Saloon 1.6 GXe
    Chassis:
    N15
    A N16 with a 1.4? Are you sure..?
    To my knowledge they were equipped with either a 1.5l or a 1.8l engine. The 1.4 engine was on the previous model (N15) Almeras. I'm pretty confident that you have the 1.5l (QG15DE) engine.
  3. David Gall
    David Gall
    2
    0
    Model:
    Almera 2004 1.4 SE
    Chassis:
    N16
    Yea i think you may be right, i think i was told i had a 1.4. Just checked the documents and it is a 1497cc engine.
    Thanks for getting back to me so quick, i wouldn’t have checked the docs otherwise cause i was sure it was a 1.4
  4. Nugget Beercase
    Nugget Beercase
    216
    39
    Finland
    Model:
    Saloon 1.6 GXe
    Chassis:
    N15
    No problem, and yeah 1497cc is rounded up to 1.5l. :)
    Did the old gearbox break? The 1.5 is paired to a quite weak gearbox, I've seen many with damaged bearings. They first start whining / making noise or vibrating and then suddenly go out.
    At some point there was discussion about possible underfilling (not enough gearbox oil) from the factory.
    Anyway, if you get a used 1.5 gearbox, be sure to change the gearbox oil unless you know its' history. The correct transmission code is RS5F30A and model number is 4M506. (with possibly a letter after, I've seen boxes with V, VB and VC after the 4M506)
  5. Sam
    Sam Moderator Staff Member
    20,123
    5,173
    South West
    Model:
    VZR N1
    Chassis:
    N15
    the filler plug was manufactured too low on the box, so you cannot put enough oil in, causes the failure of the box, incredibly common issue and a known fault, no guarantee a replacement box wont suffer the same fate.
    Dismiss Notice
