New Almera Tino owner
Discussion in 'Other Almera Discussion' started by TinoDriver, Feb 7, 2019.
  1. TinoDriver
    TinoDriver
    1
    0
    Model:
    Almera Tino 1.8
    Chassis:
    2005
    Hi all,
    I bought a 2005 Almera Tino 1.8 last year. It has 104,000 miles on it and it's generally been ok to drive. I've replaced a few things on it such as a new battery, exhaust back box, new front discs and pads and a few bulbs.
    The only issue with is that it tends too use a fair bit of oil.
    Could this be down to the age of the engine, or is there something else that I'm missing altogether?
    Thanks.
  2. Nugget Beercase
    Nugget Beercase
    215
    39
    Finland
    Model:
    Saloon 1.6 GXe
    Chassis:
    N15
    Some 1.8 engines suffered from having a warped cylinder (number 4) due to overtorquing certain bolts during the assembly process.
    Check your spark plugs, if number four looks worse than the rest then it's that.
    I have seen some 1.8s with jammed piston oil control rings as well. If the maintenance history isn't the best oil change wise or it's been driven a lot in stop-and-go traffic, this could be a possibility.
    Other more generic options would be PCV system issues or oil leaks.
    Dismiss Notice
