Newbie. 99 1.4 Almera ABS light on
Discussion in 'Newbie Section' started by dm575, Aug 8, 2019.
  1. dm575
    dm575
    6
    0
    Birmingham
    Model:
    Si
    Chassis:
    N15
    Hi all, first post be gentle :)
    Can you someone pls give me the definitive method for flasing out the ABS error codes. I've read pin 4 to ground but want to be certain I've got the right pin. Connector is beneath the steering wheel by the fuses.
    Is pin 4 top or bottom row.
    Thanks and appreciate any help.
  2. dm575
    dm575
    6
    0
    Birmingham
    Model:
    Si
    Chassis:
    N15
  3. dm575
    dm575
    6
    0
    Birmingham
    Model:
    Si
    Chassis:
    N15
    Scanned and found 35 & 36 error. Looks like the rear left ABS sensor is playing up. New one on order. Fingers crossed that's the problem.
  4. dm575
    dm575
    6
    0
    Birmingham
    Model:
    Si
    Chassis:
    N15
    Replaced the sensor and all fixed. Great info here guys :)
    Dismiss Notice
