Nissan almera 2003 timing chain
Hi if I remove the rocker cover from the engine is there anything I can look for which will show me if the chain is in good condition or if it is stretched?
thanks
You can check the chain tensioner. If it's extended more than 12mm then it is up to the limit of adjustment. There is a thread somewhere that has a diagram on it but I can't find it at the moment.
thanks for the reply. What is the maximum the tensioner car extend to
thanks
12mm is the limit. That is a sure sign of chain stretch.
Just would like to add the car driver perfect, and has plenty of power will no missing, if the chain is gone would there be any problems with the car running?
Also Where can I find the diagram please
You would get an engine management light come on which would relate to running lean on bank 1/2 or perhaps a cam sensor fault. There's nothing you can do to prevent it really. It's more a matter of fixing it when it's gone.
thanks for the diagram, so do I just measure the tensioner thing, number 9 in the pic? Also I have a new timing chain kit laying around the house, had a look at it and the tensioner in the box and it extends to 26 mm fully out, I can push it in and out but it only does in and out around 7mm.
heloo , help me please .
sry my english
my nissan alemra n 16 1.5 petrol year 2000 hatchback
Please write me original nissan part numbers for all part viz pictures member Spook and tip and link for buy original nissan parts.
thy all
OK, new hear so be patient. I have been told the engine needs to be dismantled to change the timing chain - it this correct?
