No brakes. HELP!!!
Ive recently changed my spindle and since then, when I mash the brake, it goes straight to the ground. The brake starts holding at about an inch before the pedal reaches the ground. ive changed brake pads and the MC on the advice of my mechanic but none have made a difference thus far.
It sounds like it has lost fluid from one of the two brake circuits,look for fluid loss/wetness round the wheels,if nothing found,then it could be the master cylinder.
Your mechanic should really do this,you shouldn`t be fekking with the brakes if your not sure.
Good luck,i hope you didn`t die.
What are you calling the 'spindle'
And have you bled the system up? Sound like you haven't.
....Phone.....
Ah the thought of messing with the one thing that stops you on the advice of a 'mechanic' ever since you changed that damn spindle!
Sent from my iPhone using Tapatalk
