Radio removal/change guide N15
Hi guys
Just got a new Pioneer X6600 DAB radio for my N15 SRi, just wondering before I take the whole dashboard apart and bodge it whether someone could point me in the direction of a removal / changing guide on the forum ?
I think from what I've seen its several screws in the centre console..but would like to double check first !
Thanks
Dan
Two screws in the centre. Then pull it. It's on clips. Remove the plugs for the dash buttons then it's off. You'll then see some bolts holding in the stock stereo (or aftermarket unless it's on a cage)
Undo those and unplug the stereo. You will then need to keep the two plates that are bolted to the stereo and fit them to your new unit. And put together in the reverse order.
