StevenC said:Had to take the whole door apart when I changed the handle on my 00 plate, and it should be the same.
The bit with the window controls and bit with the wee cubbyhole/armrest just come right out (grab and pull firmly) to reveal four (I think) screws. I think there's also a couple of those stupid plastic pop studs that you push and they come out.
Undo them and then lift the whole door interior off.
I never bothered changing mine as the 6x4's are over priced and they are not as good quality as the 17cm's. just cut 17cm holes in the shelf if i was youscdavis said:incase u wanna change the rear speakers aswell they are 4x6 (or 6x4's)
Darren198712 said:off topic
use 25mm MDF and make a shelf and get some black carpet
