Dale said:Yeah, but It would reduce the throw though? confused.
the nut and bolt are normaly supplyed?TheSam101 said:Might try and fit mine tomo,
Is it straight forward?
What size nylon nut does it need?
Dale said:Well i still think im right.. until proved otherwise. lol :O
My previous diagram shows that the throw is clearly reduced.
A 'short shifter kit' offers a different means of altering the gearstick throw by giving more leverage by adjusting the pivot point. This allows you to maintain the standard shaft length and have reduced throw.
However, A shorter shaft allows you to get to the same shaft angle (as a standard shaft) to engage gears but with less distance to travel. :roll:
