SR20DE LSD aftermarket
Anyone using these?
Links Pictures please.
nismo
phantom grip
aftermarket lsd
quaffie diff
Anyone using these?
nismo
phantom grip
aftermarket lsd
quaffie diff
so what is the diffference between a viscous and mechanical lsd?
i know the differences between the 1/1.5/2.0 mechanicals lsd's but not the dif between the viscous-mechanical?
itll still ok for my turbo tho ay rowdy? beter to have somwthing than nothing atall
Viscous LSDs are less efficient than mechanical types, that is, they "lose" some power. They do not stand up well to abuse. In particular, any sustained load which overheats the silicone results in sudden permanent loss of the differential effect.[5] They do have the virtue of failing gracefully, reverting to semi-open differential behaviour. Typically a visco-differential that has covered 60,000 miles (97,000 km) or more will be functioning largely as an open differential; this is a known weakness of the original Mazda MX-5 (a.k.a. Miata) sports car. The silicone oil is factory sealed in a separate chamber from the gear oil surrounding the rest of the differential. This is not serviceable and when the differential's behaviour deteriorates, the VLSD centre is replaced.
