Tino 2.2 diesel hot starting fault!
Hi can any members help with my problem please.. I have hot starting trouble, the car cranks but wont start, then wont crank (no click either, after about 40-60 sec of cranking).
Car wont jump start . Then after about 5-10 minuits the car starts fine? it has happend 4x now. I fitted a brand new battery, have no fault codes, engin coolant temp sensor shows ambient temp when cold, rises to 90'c when warm. Air filter is new, MAF/intake sensor cleaned with STP MAF cleaner. Car runs and idles ok when its going ;-) im out of ideas :-( Many thanks Graham .
2004 yd22ddt 82KW
Sorted! started with the cheapest and simplest, Diesel filter, replaced and runs fine!!!!!! ;-) could mean the diesel pump is on the way out but who knows might last 250km might last 25000km..
