Upgrading tweeters
skins1612
AOC Member - RIP 1985-2008
Hi, has anyone fitted new tweeters into where the standard ones are? Im guessing a bracket would have to be made up to mount them in. Has anybody done this?
Jack
Jack
remove the pillar and have a look behind it :)
you may be able to use the original brackets from the tweeters your buying. if the base is a clip and under the clip is a screw drill into the a pillar and then mount the tweeter onto the bracket and then change the wiring :)
