when i went to wire my door speakers up the input for the speakers? wel i cnt work out which side of the flat wire thing is for positive is negative? any ideas would be greatly apreciated
consett_GTi said:how did you get wires from the door to the head unit? which wires going into the headunit are the front speakers?
BLACKPOOLMERA said:I didn't use the grommet mate
Here's a pic for you to see what I mean.I know it's not the best option but it was simple to do without drilling into the A frame
Darren198712 said:Just make sure the metal does not cut into the wire or you are screwed. any way I think that its best to use gromets. I have put mine into the original grommets i have a N16 so its different.
swanny2k said:Ive gone through the rubber pipe which tales the wires for the door electrics with some uprated speaker cable. Takes a while, but worth it when its done.
