Maybe he typo'd N15
must be, his profile says he has an N15 GTi
pearse, you can advance it to 17 or 17.5 if you follow the correct procedure, which I cant be arsed to find just now.
Join up and search for it, but be aware some people have trouble getting the ECU into the correct mode for adjusting the base timing. This means the ECU will reset it back to its factory setting undoing all your hard work.
Trug
I still don’t know how the ecu could retard the timing which is manually adjusted anyways.
I knew the standard ecu was clever but to pull out a 12mm spanner slacken the distributor,
move it and then tighten it back without you know is a well clever trick.
dont see it
