Advice on ICE pls
  • Thread starter Thread starter Bytephreak
B
Bytephreak
I've installed some ice over the weekend budget stuff for now since i have just ended up with a mortage. Anyway when running at a decent volume my lights dim when the bass hits. Any suggestions on how to solve it? Better battery or powercap? Both? Advice please since I know nothing about audio shizzle.
Cheers guys
powercap might help, but depends how often yours lights flash to the bass, if its just when the bass 'drops' every now and then, a power cap will help this, if your lights flash constantly to the bass then a power cap wont help, as it will be draining the power from the battery as fast as the bass is using the extra power for the amp
I had the same prob, and wasted £150 on a power cap before having to fork out for a new uprated battery, powercap's look canny in installs though one good use for them :)
Nice one cheers guys will go for a uprated battery first then and if the problem is still happening will get a powercap.
Its not all the time its ok at low volume but when its on loundish and the bass drops low than when they dim not all the time.
Again my thanks
