advise needed asap deglobing
rite guys i need some quick advise on deglobing the front indicators. now before anyone says do a search can someone just tell me if i need to break the amber casing inside the idicator or do i need to do something else thanks.
either put it in the oven for 5 mins on 100degree and seperate the casing from the lense. or put it in boiling water to do the same. alternatively use pliers to crack the amber globe and let the bits drop out.
you do not need to oven it you could do the brute force method and get a hammer and a screw driver and then smash the inner globe and then use a pair of plyers to take the rest of the orange globe out
you dont have to take any pins off on the offset bulbs. i have offset bulbs on mine. they wedge in with a good fit. have had mine for a few months now and no problems.
