Alignment
Sam
Moderator
Staff member
Cant decide whether bonnet isnt set right,
or the head light hasnt been put in properly at some point,
I will post pictures tomorrow whence the sun has returned give you all a proper look.
Its the drivers side headlight, seems to be pulling the grill back aswell.
WATCH THIS SPACE1
Cheers
Sam
bring it down to qwik fit or somewhere and have them have them do a light alignment, pretty cheap and hopefully will fix the problem
Brilliant if its that simple,
things arent generally that easy for me though. :(
Sam
to check if its the bonnet, are the panel gaps the same with the bonnet and front wings on both sides? should be obvious if its not. has it been in an accident at some point? is the slam panel straight? hard to say without seeing it but could be down to a cheap accident repair and the metal behind the headlight is mangled
