I have a 5 door Almera Action 1996/7. The ignition switch and drivers door lock are well worn, as well as the key, but the key opens/starts after a little fiddling. I have just lost the key with transponder and I think I will take the opportunity to fit a newish used ignition/door locks - they pop up on ebay every now and then for about £50ish.
I coud pay £130 for new key/responder but the locks are on their way out so I may as well replace the ignition and drivers side locks (for less money with luck). If I bought an ignition and door lock off ebay or a breaker's yard would I be able to easily remove the existing ignition key lock from the steering column and replaced with another? Is the air bag easily removed/disabled. Are there shear bolts on the ignition switch?
Thank you for any advice - Andrew (stuck without his car)
