Hi
I have a 2003 Nissan Almera 1.5S RHD. This has the ecu/ecm in the cabin. I have a shorting problem on the ecu/ecm side of the ECM Relay which blows the 10A fuse. The ECM Relay pin 3 feeds the ecm at 110 and 112 but does so through the Joint Connector-6 F114 pin 1, but one of the circuits on that busbar is shorting out. I cannot find anywhere a statement as to what is connected to pin 1, though a pdf search has given the camshaft sensor and the crankshaft sensor.
Could someone send me a list of things connected to the Joint Connector-6 to save me cutting the loom
