Nice build! Both engine and interior looks good!
If you have any info on what's needed to do this swap, please share!
Did you need new enginemounts? Anything else that is good to know about?
Engine mounts from VZR, but front and rear mount may be from GA or P11 SR with some custom. The most big problem is gearbox and driveshafts. If you use 2.0 Primera gearbox, you should find GTI driveshafts. if you use VZR/Pulsar/Autech Gearbox, you should use driveshafts for LSD.
OK, do you think P11 mounts will fit all the way around? So I probably need GTi/VZR driveshafts for the bould then,
I have a P11 SR20VE front cut coming in from Malaisya soon, so I'm trying to gather as much info as possible.
Thanks a lot!
Thanks for info boys!
I assume the same thing goes for the CVT gearbox, so when the time comes I'll have to find some GTi mounts then, probably easiest to find some on here.
