ALMERA GTI INFO NEEDED???
im looking at a 1997 almera gti as a runabout but know nothing of them so thats why i joined up here!!
what should i look out for with the almera when i ask him about it!!have pics and will throw em up!!
how much should a 97 almera gti be worth(irish lads) shes standard and will have 2 years fresh nct!!
any info appreciated!!!!
cheers lads!!
Hi mate
You shouldnt really be paying over £750 for a decent 97 gti
Things you should look out for are rusty wheel arches and sills, noisy gearboxes and noisy driveshafts these can be on these can a problem sometimes
Other than that it should just the obvious stuff to look out for i.e signs of misuse, oil levels, water levels service history etc.
To be fair as long as looked after these are bullet proof engines and all round a very reliable motor
Good luck:)
The following post describes common problems with the N15 Almera and brief descriptions of fixes, more will be added if they become widespread!
Common N15 Almera problems/what to look for when buying an Almera
The N15 Almera suffers from very few inherent faults and was built at a time when Nissan were building probably the most reliable cars in the world, Almera’s with over 200,000 miles on the clock crop up for sale sometimes and show no signs of failure. The engines are pretty bullet proof so there’s not much to mention about them when looking at buying one apart from the normal rules with any car (check it has service history and there are no weird noises or leaks etc! – the GTi engine has a loud idle anyway due to the tappets, so if it has service history and the rest of the car seems ok it may not be anything to worry about, just use your judgement!).
Afew common flaws with the cars though:
Rusty rear arches:
Check the arches for bubbling around the arches, particularly the rear ones as they have a habit of rusting, also check the sills which may or may not be visible depending on if the car has sideskirts. As an added note, many Nissans from the 90’s begin to rust around the rear suspension turrets and I have seen afew early Almeras with the same problem, it’s not widespread yet (as of 2007) but could be something to look for as the years go on, to look, take off the boot carpet and check the panels the rear shocks mount in for signs of rust, also do the same from the exterior, by running your hand up the wheel arch to feel where the suspension mounts. Also on the subject of rust, check the downpipe as it can rust through.
Power steering fluid leak:
If your power steering is running low, or you find a leak on your drive that isn’t oil, chances are it’s the power steering fluid leaking, something that seems to be a common fault on N15’s.
The leak occurs on the offside where the front metal cooling pipe meets the rubber flexi pipe, and just needs the broken bit shortening and a new clip (jubilee etc) sticking on! Job done.
Sidelight bulbs:
This is a pretty simple problem, the ends of the wires into the sidelight connector corrode and this stops the sidelight/s from working. To fix it take the bulb holder out, clean up the connections and solder some new wires in, then solder these onto the existing wires.
Heaters only working on 0 and max:
this happens on a lot of Nissans from the period not just Almeras, the speed of the heater blowers is controlled by a variable resistor on a circuit board. This resistor is controlled by the dial and if it burns out the fans will only work on the first and last settings (e.g. off and max). There are acouple of ways to fix it, cheapest being to remove the heater card from the dash (the circuit board) and solder a bridge over it, or a new resistor, or go to Nissan and buy a new heater car (they’ve replaced the original design with a more up to date one now) which are around £30 at the time of writing.
GTi Brake callipers seizing:
Quite common, the car will judder or ‘chug’ and the affected disc will become overly hot, the brake piston has seized out forcing the pads into contact with the disc at all times, if this goes on for a while it can cause a warped disc, in which case you’ll need a new disc! Possible fixed include refurbing the caliper using a brake refurb kit, or alternatively buying a refurbed caliper (Brakes International sell both).
If this has occurred as a result of the pads wearing right down and the piston pushing too far out to go back in, just changing the pads and forcing the piston back in (I got a garage to do mine) could be enough.
Central locking going mental:
the central locking system seems to have a habit of going mad, locking when it wants, unlocking when it wants, only unlocking for three seconds, but yeah, anyway – it’s most commonly caused by moisture getting into the actuator in the offending door. To fix it, strip the doorcard off the door and spray WD40 maintenance spray (expels moisture) all over the mechanism, this will drive out the moisture and the locks should behave!
Those are the main problems which people ask about all the time so hopefully it will save people posting, if anymore start to become common as the cars age I will add them on the end!
