Almera gti+t lambda question?
one for the turbo heads..
what way do you guys have your lambdas fitted..
ive a gtir one there into the elbow but the connection on the end is the same as the connection from the loom(so they cant slot into each other)..
do you have to snip and solder together and if so what way..gtir lambda has red,white and black wires where the stock gti has white, white ,black..
thanks
Like I said on Facebook, the GTiR lambda will not work with a gti ECU. They operate totally different
Fit a bigger boss for the gti lambda
