almera n16 jumpy
Does anyone know why my almera is jumpy when the engine is cold in the mornings? She is fine after 5 minutes and as far as I am aware she is mechanically sound because she has brand new timing chain and starter motor. Any thoughts?
My 1.8 does it as well. Usually happens if i am in a higher gear than needed. Dropping a gear solves everything. After warmed up all is ok. Maybe thecoils need changing?
think its just the cold start try slightly adjusting the throttle cable it'll up the revs a bit n may cure the problem (i did say may) lol
