Almera Ph2 GTi
  • Thread starter Thread starter momo
M
momo
Yes,Almost ready to bring the car out of the Garage! purchased a Blue Almera Ph2 Gti , its lowered and sits on 18" Wheels and has a Hks Induction Kit ,big bore Exhaust that sounds sweet when u take it up threw the gearbox !
A few niggly things wrong but well impressed with the car
- the heaters work only on 4 (thanks for the reply on sortin the problem)
- Power steering fluid leak where it joins to the metal pipe.(Any advice Please)
Great forum People very informative it has answered alot of questions.
Pictures should be up soon !!
Momo
Momo
Remove grille, indicator and headlight from drivers side (all easily done) and replace the 2 rubber pipes that run from the steering resivoir metal pipes to the metal coolant rail that runs through the front bumper. Also check this rail for leaks as both my pipes and rail were at fault. Source bits form here or a scrappy as Nissan want stupid money for the components. Cost me about 10 quid all in to sort mine. Hope this helps.
Thanks Damo-Sri for your reply, sorry i couldnt get back to you earlier.im going sort it in the next couple of days.
Also once its been done how do you go about gettin rid of any air in the power steering system? i will Let you know the outcome.Cheers....
