I have an 03 plate nissan Almera n16...It has started juddering under acceleration and the engine management light is on. Have replaced both cam/crank sensors...
Took rocker cover off and engine side casing, have noticed the the plunger from the tensioner is protruding by about 14mm and is past the ratchet on the tensioner...Does this mean I need a new chain? If so have Nissan strengthened their new chains or am I better buying from a motor factors?
Cheers...Keith
Cheers...Keith
