Hi
I'm trying to check the chain tension on my son's 2004 1.5 petrol Almera as he is having 'revving' issues. I have removed the nine cover bolts and the two 12mm bolts (under the loom at the back) but cannot get the cover to budge. I've tried tapping it with a lump hammer, using a lever, chisel, pleading with it and even shouting but it will not move even a millimetre. Am I correct in assuming that once the 11 bolts are removed it should start to lift - I see there are two locating pegs on the n/s of the head so the cover presumably can only move upwards. Although I've removed them I cannot see why the two 12m/m bolts at the back need to come out also - surely they hold the inlet manifold to the head not the rocker cover? All the ancillary wiring is either removed or has sufficient play not to be an issue
Have I missed something?
