Alternator belt removal
Hi all,
I have a 1.4 almera, and the alternator belt broke off last night and i got a replacement, the problem is that i have no idea how to remove the outside belt ( water pump/ power steering ) if somebody could point me in the right direction id be very grateful, thanks
Emmet
You have to loosen one 14(?)mm bolt holding the pump in the bracket, so you can swing the pump towards the front of the vehicle to give the belt some slack. Best access is from underneath the vehicle.
EDIT: Forgot to mention that I'm talking about the power steering pump :D
Thank you, I'll give it a go when it stops raining haha
