P
peverley31
does anyone know were is the best point to take the amp power cable through the bulk head?
Phil_GT said:the girlfriend was on about getting me a sub and amp but i didnt know where to find a gormmet so lost interest in it.
also i like being able to use my boot and not have it full of sub boxes.
on this note what would people suggest just for a nice bit of bass without robbing my whole boot.
I would take it though the grommet near the passenger side. take all the tape off and then put the power cable though and then tape it back up again don't want water leaking in now or a short in the cable.sri_alan said:just where the passenger footwell carpet stops, in the middle, there is a grommet about the size of a 50p, screw driver that and feed it on the power cable. run the cable through and push the grommet back in place
yeah they are not bad for what they are if you want to save space. but if you want good bass you need to loose the spaceHally said:You can get under-seat subs. dont thing they're as good as normal ones but if you need the space...
Darren198712 said:I would take it though the grommet near the passenger side. take all the tape off and then put the power cable though and then tape it back up again don't want water leaking in now or a short in the cable.
I did own one beforesri_alan said:Do you own an N15? No. So therefore you have no idea what I am talking about.
sri_alan said:What tape are you on about? The gromet is made of rubber. When you force the cable through a small hole made in the gromet, this actually seals it. Incredible, I know.
How can you short an insulated cable just by water touching it? Unless there was a cut in the cable then you cant.
you said screw driver that did you mean remove the grommet or just put a hole in it ?sri_alan said:just where the passenger footwell carpet stops, in the middle, there is a grommet about the size of a 50p, screw driver that and feed it on the power cable. run the cable through and push the grommet back in place
scott b said:no kurt, standard is shite
